ProjeQtOr free project management software - 'Dispatch work' hidden - ProjeQtOr
09 Nov 2016 13:50 #1 by caccia
Don't know if I did something wrong on my test instance, or if this is a feature:
on some tickets, I don't see the 'dispatch work' button displayed (logged in as admin). On other tickets, the button is there as expected.
Are there some conditions required in order to display this button, or should it always appear ?
Cheers!
09 Nov 2016 16:04 #2 by protion
Replied by protion on topic 'Dispatch work' hidden
I would tend to a problem on your system, because on my test system, the button sends and permanently available.
cordially
Bonjour
Je pencherais plutôt pour un problème sur votre installation, car sur mon système de test, le bouton envoie et disponible en permanence.
Cordialement
09 Nov 2016 16:10 #3 by caccia
Replied by caccia on topic 'Dispatch work' hidden
OK, thanks for the quick confirmation - I'll start from a clean environment : too many different tests in this environment I guess !
09 Nov 2016 16:12 #4 by protion
You're welcome
Good continuation
De rien
Bonne continuation
