ProjeQtOr free project management software - [SOLVED] Problem in SQL query with a user - ProjeQtOr
04 Oct 2016 12:31 #1 by GNDuser
Hello.
We are having a trouble with a user that is logged in Windows with his user domain and also logged in Projeqtor with his user inside projeqtor. there is a Project and when is loaded Requeriments the query stuck and show a message that says: "Query on Going". Another user in Projeqtor haven't this problem in the same Windows sesión and can show Requeriments perfectly.
This user with another login in Windows but with his user logged in Projeqtor can see requeriments and show then normally.
Only the problema appears when he is logged in Windows and Projeqtor,
All this is made via Internet Explorer 11 and Windows 7.
What can it be happening?
Thank a lot.
05 Oct 2016 15:07 #2 by climb4fun
Hi GNDuser,
there is a post which deals with the same topic from you. Is it the same or a new issue?
Klaus
05 Oct 2016 15:47 #3 by babynus
Same question as for other post : please check browser console.
I'm pretty sure you'll get errors, and most probably "connection issue" : I guess one of the security elements (firewall, antivirus or other network security element) ends the connection because of some specific rule (maybe some forbidden key word found in the request, or any other kind of rule)
06 Oct 2016 18:17 #4 by GNDuser
Resolved.
It was a problem about antivirus configuration.
Thanks to all.
