ProjeQtOr free project management software - Idle users are somehow being picked up in Resource / Assignment dropdowns - ProjeQtOr
03 Oct 2016 09:17 #1 by sagar.toshniwal
V5.4.3. I had created certain users for testing and after a while, I don't need these anymore. So i changed "idle = 1" directly into the database. I don't see these users in the list of Users, but I am still able to see these (idle) users in the dropdown for Resource / Assignment. Please refer the screenshot.
I am not sure why the "idle = 1" values are being fetched. Are there any additional dependencies? Can you share from where this dropdown is loaded? Do we need to modify the sql command used to populate this dropdown? If yes, please help where...
I am an Eagle. On a mission to help those who want to help themselves...
04 Oct 2016 18:35 #2 by babynus
You should never do this
Because your resource still have not idle affectation to projects.
No, you just need to avoid direct updates in database so that the persistence frameworm can operate and bring consistancy.
For instance, to set idle several users at same time, export them, change idle value in csv file, and reimport ;)
