ProjeQtOr free project management software - [SOLVED] Problem: Real Work Allocation not visible - ProjeQtOr
29 Sep 2016 20:54 #1 by isilva
we recently installed projeqtor 5.5.0 (with MariaDB) and have started to load our projects.
On my local computer (with projeqtor 5.4.5) I had no problem with the "Real work allocation" functionality, but in the shared server, this option shows nothing. Not even the Administrative Project's tasks.
Is there any problem with this feature on the 5.5.0 version? The configuration is the same, and not even the administrator sees these forms.
Please your help to know what to do. Maybe a downgrade to 5.4.5 or an upgrade to 5.5.2?
Thanks,
Ignacio
05 Oct 2016 09:26 #2 by babynus
It's not a problem, its a new feature : projects "under construction" are not displayed in real work allocation.
And new projects are automatically "under construction".
Si you need to change projects status or uncheck the "under construction" flag.
This new featur is somewhere confusing, so we'll think on an improvement.
The following user(s) said Thank You: isilva
