ProjeQtOr free project management software - [SOLVED] work assignment - ProjeQtOr
03 Sep 2016 18:28 #1 by mcambron@videotron.ca
I am starting to use Projeqtor and I have a question.
I created a project with task and I assigned a resource to work on one of the task. I created a new profile : responsable de test which appears in (brackets) . The resource is also a user ( Testeur1) with a pass, word. The project is ''accepted'' state.
When a login as the Testeur1, I see no data and no menues, see attached file. Could you please tell me what I must do so that when I log in as testeur1 I can see the task that I assigned to Testeur1?
Michel
03 Sep 2016 19:36 #2 by babynus
Replied by babynus on topic work assignment
As you created new profile, it is normal that its name appears between bracket. It is because profile name is translatable and no translation exist for your profile name. You need "personalized translation" plug-in to translate it.
About visibility, it is due to access rights that you must define for new profile. You also need to affect user to a project to see its data...
03 Sep 2016 20:36 #3 by mcambron@videotron.ca
Thank-you for your fast reply,
The ressource is asssigned to a task (see file testeur 2) but under «planification par ressource» , there is no data to display see file testeur 3.
Merci
Michel
04 Sep 2016 00:21 #4 by babynus
Your print screen shows that you named a responsible for the activity.
But you need to assign so work to some resource (that may be different from responsible).
Could you show the assignment section ?
Then you'll have to execute planning calculation before seeing something on the resource planning.
07 Sep 2016 02:07 #5 by mcambron@videotron.ca
I have assigned a ressource testeu1 to the project la banque du Québec and i have affected the ressource to the project see sreen shot testeur 4 and testeur 5. He is assigned to a task see screen shot testeur 2. Do you have enough info to tell me what I am missing so that I can sign in as testeur 1 and see my work and enter activities?
Michel
07 Sep 2016 14:43 #6 by richard.pare
Replied by richard.pare on topic work assignment
You must assign work to resource in the "Assignation" section.
To see, planning in the Gantt view you must build the planning. Click on the gear icon.
The responsible "Responsable" is not necessarily a resource who work on the task or the delivery. The responsible is like a foreman.
The following user(s) said Thank You: mcambron@videotron.ca
Time to create page: 0.100 seconds
