ProjeQtOr free project management software - [SOLVED] Quotation/Order/Bill how to? - ProjeQtOr
02 Sep 2016 02:06 #1 by DrilonUV
Hey Guys, loving Projeqtor so far and just getting into it so quiet new to it.
When starting a project, How do I actually send a quote out? The quote tab does not allow to start anything new and I have read through the user guide to no avail. Im trying to get Bills sent to customers via projeqtor so I can run reports on our clients however I cant seem to figure out how to generate a quote/order/bill? Is it possible to skip generating a quote all together and just attach a bill to a project with cost's so that I can run the reports that way? If so how?
Regards and thanks for the good work.
02 Sep 2016 10:21 #2 by babynus
You'll find bill report on Report screen.
This can help you edit a bill.
You can also copy this report file /report/bill.php as /report/object/Bill.php, and this will become default print sheet, that you can export as pdf, and possibily customise to your needs.
You can so customize reports to fits your need (need to know some PHP). If you don't have devs capacities, we can do it for you (request for a quotation through the contact form)
05 Sep 2016 02:04 #3 by DrilonUV
Thanks for that, Ill have to send through a request soon.
