ProjeQtOr free project management software - [SOLVED] cannot limit access right of Project Manager as a simple viewer for a defined project - ProjeQtOr
22 Aug 2016 11:24 - 23 Aug 2016 08:45 #1 by cmarechal
a have a problem of access rights i can't solve :
User1 has a profile of Project Manager
but in the project1 he is only a viewer (read only access - profil of viewer in the project affectations)
-when user1 is connected to Projeqtor he can create elements (as a Project Manager) which are for its own projects. But he cannot create element as element of the project1. By now; everything is normal.
-when user1 uses the project combo box at the top-left of the screen and go to the project1, on the filtered screen of planning (planning of project1) he can create sub-project, activities and milestones linked to project1. Is it normal ?
once created, user1 cannot delete this elements belonging to project1 even if he has them himself created ! Strange...
thanks for your help,
Christophe
Last edit: 23 Aug 2016 08:45 by cmarechal. Reason: more explicit
24 Aug 2016 22:19 #2 by babynus
You are right, this is not normal.
Issue recorded as Ticket #2281
25 Aug 2016 08:35 #3 by cmarechal
29 Aug 2016 13:50 #4 by cmarechal
after the V 5.4.5 update, the problem is solved for activities and milestones but not for projects :
you can always create a subprojet in a project where you are not allowed to access (except as a simple viewer)
