ProjeQtOr free project management software - Problem with "accented letters" - ProjeQtOr
10 Aug 2016 15:17 - 10 Aug 2016 15:19 #1 by djconcept
after a server migration, we have problems with all accented characters.
Can you tell me where does the problem? Is this a problem with PHP 5.6? It's the only big difference between the two servers?
thank you in advance for your help. Best regards
edit : [ProjeQtor V5.3.3]
Last edit: 10 Aug 2016 15:19 by djconcept.
10 Aug 2016 15:27 #2 by babynus
No, it is a difference with encoding.
Check your MySql configuration to ensure server is in UTF-8 format.
10 Aug 2016 15:27 #3 by babynus
NB : possibily you'll have to re-import data to retreive accents.
