ProjeQtOr free project management software - [SOLVED] Session Destroy giving error on first click, later on it works fine in Audit.php - ProjeQtOr
26 Jul 2016 11:09 - 26 Jul 2016 11:13 #1 by sagar.toshniwal
In v 5.4.2, when I click on "Disconnect" (Log Off) button, it throws below error for the first click. On second click, it works fine. Googling does not give satisfactory results specific to our tool, so what can be done to address this?
2016-07-26 14:24:49.434 ***** ERROR ***** on file 'C:\wamp\www\projeqtorV5.4.2\model\Audit.php' at line (214)
2016-07-26 14:24:49.434 ***** ERROR ***** cause = session_destroy(): Session object destruction failed
The line #214 under question is as follows:
213		  try {
214			  @session_destroy ();
215		  } catch ( Exception $e ) {
216			  // tried twice : OK let's give up.
217		  }
I am an Eagle. On a mission to help those who want to help themselves...
Last edit: 26 Jul 2016 11:13 by sagar.toshniwal. Reason: Code formatting
27 Jul 2016 18:43 #2 by babynus
I cannot reproduce.
Is it systematic ?
What browser on what OS do you use ?
02 Aug 2016 14:20 #3 by sagar.toshniwal
Even I could not reproduce. :angry: :ohmy:
I am using IE11 on Win 8.1. I know this is a stone-age configuration but I can't do anything as it is my work laptop. :)
02 Aug 2016 15:46 #4 by babynus
Some are still working with IE8 / Win7 :silly:
So let's forget about it unless your reproduce.
14 Sep 2016 11:27 - 14 Sep 2016 13:50 #5 by ashofphoenix
Same pb here ! :)
2016-09-14 11:19:01.853 ***** ERROR ***** ERROR *****
2016-09-14 11:19:01.862 ***** ERROR ***** on file 'D:\Intranet\htdocs\projeqtor\model\Audit.php' at line (219)
2016-09-14 11:19:01.871 ***** ERROR ***** cause = session_destroy(): Session object destruction failed
WIN7/64b - Apache 2.4 / PHP7.0 / Firefox 48.0.2 / Projeqtor 5.5.1
www.projeqtor.org/fr/forum-fr/5-ask-ques...destroy-giving-error
Last edit: 14 Sep 2016 13:50 by ashofphoenix. Reason: unsolved post
14 Sep 2016 12:02 #6 by babynus
Issue should be fixed on V5.5.2.
NB : please do not post on [SOLVED] item.
