ProjeQtOr free project management software - Question before plugins installation - ProjeQtOr
20 Jul 2016 20:18 #1 by dnaton
One question before the installation :
What's happend if we decide to supress the plugin when they are used (screen customisation an personalized translation)
In this case, what's happen with customisation ?
Damien
20 Jul 2016 21:24 #2 by babynus
There is no feature (yet) to remove plugins.
But for screen customization, if you remove the plugin directory, you won't loose changes you've applied.
You will just not be able to make more changes.
Important : when you make some changes on a screen, you have a feature to revert your changes to get back to standard screen (king of "removing" the customization for the screen)
