ProjeQtOr free project management software - Problem with affectation in the "Project" screen - ProjeQtOr
13 Jul 2016 11:38 #1 by dnaton
I've got a "space case" when I try to affect a ressource in the project screen, when I'm connected with a profile "Team Member" or "Project Leader"
First try
  • I'm connected with user with "Team member profile". If I try to insert a new affectation, I have the right screen to do it, I save my input, Projeqtor say me "Affectatoin saved #125" but.......I don't see anything in the scree of th project.
  • If I connect me as the user concerned by this affectation, he has no affectation on this project.
  • If I connect me as Admin, it is the same, no affecttion on the project
Second try :
  • I affect the ressource on the project with the screen "Affectation" : in this case, it's ok : the affectation appears on the project screen :dry:
My question is :
  • What is the difference between input an affection directly in the project screen and input the same affectation via the Affectation screen ?
  • I think there is probably a problem with right access but where ?
Damien
13 Jul 2016 15:17 - 13 Jul 2016 15:25 #2 by dnaton
After a few new tests, the situation is already "space" ;)
I already connect me to Projeqtor with a user "Team member" profil (with right to manage affectation)
If I create an affectation via the "Affectation" screen, it works and the affectation appears on the project screen (I knew already)
But what is new :
After this "manipulation", I can create an affectation directly in the project screen :blink:
And a problematic "board effect"
If I give to a Team Member user the right to see the "Affectation screen" and the right to create an affectation, he can also add himself as ressource but with a profil of "Administrateur", and then he become Administrateur on the project and can do everything he want
:woohoo:
If I disconnect from ProjeqTor and reconnect, I lose this possibility (create directly in the project screen), except if a do the same manipulation described above
Befor, I thought it was a problem of right . But after this new test, I'm not sure.
Can anyone reproduce the same case ?
Damien
Last edit: 13 Jul 2016 15:25 by dnaton. Reason: add some new informations
15 Jul 2016 14:41 #3 by babynus
Issue confirmed.
In fact issue occurs on first display of affectation pop-up.
If you open it once : you'll see selected project is not the correct one.
Just close and reopen affectation pop-up : now it's right.
So this may be a workaround.
We'll analyse it and soon propose a patch.
