ProjeQtOr free project management software - [SOLVED] 3 questions - ProjeQtOr
09 Jun 2016 19:46 #1 by keloniton
3 questions was created by keloniton
Hello Dear Mr babynus,
How are you? I appreciate to know your idea about following question:
1- I know that, if i want to have access to all of the date fields in projeqtor, i just can search for datetexfield in objectdetail.php. If i want to have access to the fields which are about numerical amounts (costs or expesne or the things which are related to money). what can i do?
2- In some of project management softwares, there is a place for stocks and stock management, for example in construction and building industry the stock of soil, bricks and etc. Does Projeqtor cover the stock management also?
3- The print section does not cover persian unicode. Do you have any idea how i can fix it?
Thank you very much
09 Jun 2016 20:00 #2 by babynus
Replied by babynus on topic 3 questions
Same. in objectDetail.php. Look for dataType that is numeric (numeric, decimal, int). And for currency criteria is
$dataType == 'decimal' and (substr($col, -4, 4) == 'Cost' or substr($col, -6, 6) == 'Amount' or $col == 'amount')
No. Stock management is not part of Project Management, it is Supply Chain Management.
What do you call "print section" ?
13 Jun 2016 01:16 #3 by keloniton
Replied by keloniton on topic 3 questions
I mean printing to pdf or export to pdf as it is shown it attached photo. It does not support persian charachters.
13 Jun 2016 09:11 #4 by babynus
In V5.3 you have possibility to select font for PDF export.
Use FreeSan that integrates unicode, but I don't know if it is compatible with persian. If not you'll have to find one in TCPDF library.
