ProjeQtOr free project management software - [SOLVED] View Milestones in sub-projects - ProjeQtOr
30 May 2016 14:40 #1 by chenevieredd
Hi there,
Is there any way, on the planning screen, when it's filtered, to see Milestones from the projects above?
The problem is, the Milestone counter and the Project counter is the same for WBS calculation.
If I create a milestone in project 1.2, this milestone WBS will be 1.2.X and I won't be able to see it in others sub projects (1.2.Y) on the planning screen.
So my question is : Is there a way to have "inheritance" for milestones from the main project to the sub-projects.
Thanks for any advice.
30 May 2016 22:07 #2 by babynus
No, there is no way, and it's not planned to design such feature.
Only way in your case is to display project 1.2, and you can "shrink" sub-projects you don't want to see.
The following user(s) said Thank You: chenevieredd
31 May 2016 09:33 #3 by chenevieredd
Thank you for the answer Babynus
