ProjeQtOr free project management software - Screen "Imputation" doesn't take in account filter "Project" - ProjeQtOr
19 Apr 2016 11:29 #1 by dnaton
When I select a project in the "selector" (Up left of the screen), I see only informations of this selected project on the other screen (project, activity, ordern meeting,...).
There is only one screen where it is not ok : Imputation screen
Is it normal ? Is there a way to see only imputation only for the project selected ?
thanks
Damien
21 Apr 2016 17:42 #2 by babynus
It is not an issue, it is designed this way :
real work allocation always displays all project in order to have the sum for each day corresponding to all the work done, and so be able to check entry is correct.
You can "schrink" a project if you wish...
26 Apr 2016 14:17 #3 by dnaton
Ok, I understand.
Maybe a evolution in the future: don't display Template ? There is no imputation on this kind of project (I believe it, right ?)
Damien
28 Apr 2016 18:14 #4 by babynus
Recorded as Ticket #2064
