ProjeQtOr free project management software - [SOLVED] Project code copy with template...problem - ProjeQtOr
08 Apr 2016 10:30 #1 by dnaton
When you create a project, the field "project code" is important because it is used as prefix to name with a unique id milestone, activities,....
And this unique id can't be modify.
And the problem is (for me) when you generate a new project with a template :
  • The project code used for the copying project is the same as for template. You can change it of course
  • But the activities, milestone,....copying have the project code from template and not from the new project :(
Is it a bug or is it the right operating mode of Projeqtor ?
If yes, I suggest when a project is created from a template, to ask for his new name, but for a new project code too.
Could be possible ?
Damien
08 Apr 2016 23:09 #2 by babynus
Not really a but, but something not taken into account.
Request recorded as Ticket #2036
