ProjeQtOr free project management software - [SOLVED] Is it possible to "protect" template project ? - ProjeQtOr
07 Apr 2016 17:40 #1 by dnaton
all is in the title ;)
the idea is to protect the "template project" against unintentional modifications
  • allow users to use a template to create a new project but not to modify or delete the template itself
Is it possible to do that ? :)
Damien
08 Apr 2016 22:51 #2 by babynus
It is exactly what "Template" project type stands for.
=> you design your project
=> you change the type to Template
=> You don't affect anybody to this projects.
Then Project Leaders can see the project template in the project list, they can copy it, but cannot change it.
