ProjeQtOr free project management software - Help on document directories structure - Page 2 - ProjeQtOr
04 Apr 2016 01:00 #7 by babynus
In any case, now I can't do anything because I don't see any item in the List Window, nor in the Detail Window...
What can I do to fix the problem?
Be sure you did not select a project in the project selector (top left)
Be sure you did not apply a filter.
04 Apr 2016 08:18 #8 by Eugenio
Yes, I am sure!
And I have the same empty screen also when I click on Document in the menu tree...
04 Apr 2016 13:40 #9 by babynus
Can you check for error in the log file ?
And in the browser console ?
Also try and reset list presentation (in the column selector)
04 Apr 2016 15:01 #10 by Eugenio
I have found the Log files and I see into some ERRORS...
But I think it is better to send you the log files of the last 2 days, so you can see directly what has happened.
Furthermore, I can tell you that the browser console hasn't never shown some advice after my file operations, and that also the reset list presentation unfortunately had no effect (also because I didn't have never changed the column list for this kind of lists)...
05 Apr 2016 00:09 #11 by Eugenio
The error is always the same:
2016-04-03 09:51:56.629 ***** ERROR ***** Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'prqtdocument.idProductOrComponent' in 'on clause'
2016-04-03 09:51:56.629 ***** ERROR ***** For query : select prqtdocument.id as id, T1.name as nameProject, T2.name as nameProductOrComponent, T3.name as nameDocumentType, prqtdocument.name as name, convert(concat(T4.sortOrder,'#split#',T4.name,'#split#',COALESCE(T4.color,'')) using utf8) as colorNameStatus, T5.name as nameDocumentVersion, T6.name as nameDocumentVersionRef, prqtdocument.locked as locked, prqtdocument.idle as idle, T7.name as nameProduct,prqtdocument.idProject as idproject from prqtdocument left join prqtproject as T1 on prqtdocument.idProject = T1.id left join prqtproduct as T2 on prqtdocument.idProductOrComponent = T2.id left join prqttype as T3 on prqtdocument.idDocumentType = T3.id left join prqtstatus as T4 on prqtdocument.idStatus = T4.id left join prqtdocumentversion as T5 on prqtdocument.idDocumentVersion = T5.id left join prqtdocumentversion as T6 on prqtdocument.idDocumentVersionRef = T6.id left join prqtproduct as T7 on prqtdocument.idProduct = T7.id where prqtdocument.idle=0 and ( (prqtdocument.idProject not in (0) or prqtdocument.idProject is null ) and (prqtdocument.idProject not in (0) or prqtdocument.idProject is null or (prqtdocument.idUser='4') ) ) order by prqtdocument.id desc
2016-04-03 09:51:56.629 ***** ERROR ***** Strack trace :
2016-04-03 09:51:56.629 ***** ERROR ***** #0 Sql->query called at [/home/u296005607/public_html/projeqtor/tool/jsonQuery.php:530]
2016-04-03 12:17:07.110 ***** ERROR ***** Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column
But, obviously, I don't know what it means...
08 Apr 2016 00:09 #12 by Eugenio
using phpMyAdmin I have adjusted the tables "document", "documentversion" and "documentdirectory" of DB, and after various tests I have discovered that with version of ProjeQtOr 5.2.4 all functions very well and I see all the files and the full directory structure.
But when I try to upgrade to version 5.3.1, the problems recur (in the log file I read that there were "23 error during the upgrade to v5.3.1 version") and I can no longer see the documents and the directory tree of the archive.
Do you think that is a problem that can be solved or will I be forced to stay up to version 5.2.4 to avoid losing all my data and all customizations already made?
Thanks in advance
