ProjeQtOr free project management software - [SOLVED] Fopen error at first intallation - ProjeQtOr
27 Mar 2016 19:37 - 27 Mar 2016 19:55 #1 by Sylvain
I am French. So, My language is not good. I'm sorry
I am looking for a project management program. I found Projeqtot :)
I try to locally insttalation with:
Apache / 2.2.27 (Win32) DAV / 2 mod_ssl / 2.2.27 OpenSSL / 1.0.1g mod_fcgid / 2.3.9 mod_wsgi / 3.4 Python / 2.7.6 PHP / 5.6.13 mod_perl / 2.0.8 Perl / v5.16.3
The installation seems to be fine.
However, when I connect for the first time, I was after a long time:
ERROR: fopen (../ files / config / parameters.php): failed to open stream: Invalid argument in Parameter.php at line 804
It's strange because this file contain only 43 lines :huh:
If you have any leads, I'm interested :)
In terms of urgency, I learn to use it. So I have all the time :)
I'll put in onligne when I can better control the beast: P
Thanks in advance
(Thanks google translotor :S)
Sylvain
Edit :
I forget : OS : win 7 64 Bits
I try fopen and it run
Logs file :
2016-03-27 19:16:21.624 ===== TRACE ===== === REWRITE PARAMTERS.PHP FILE = START ====================
2016-03-27 19:16:21.624 ***** ERROR ***** ERROR *****
2016-03-27 19:16:21.624 ***** ERROR ***** on file 'D:\www\projeqtor\model\Parameter.php' at line (804)
2016-03-27 19:16:21.624 ***** ERROR ***** cause = fopen(../files/config/parameters.php): failed to open stream: Invalid argument
2016-03-27 19:38:03.856 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.user' doesn't exist
2016-03-27 19:38:03.859 ***** ERROR *****    For query : select * from user where user.name='admin' and user.isUser = '1'
2016-03-27 19:38:03.861 ***** ERROR *****    Strack trace :
2016-03-27 19:38:03.862 ***** ERROR *****    #0 Sql->query called at [D:\www\projeqtor\model\persistence\SqlElement.php:1713]
2016-03-27 19:38:03.863 ***** ERROR *****    #1 SqlElement->getSqlElementsFromCriteria called at [D:\www\projeqtor\tool\loginCheck.php:61]
2016-03-27 19:38:03.866 ===== TRACE ===== Login error for user 'admin'
Last edit: 27 Mar 2016 19:55 by Sylvain.
28 Mar 2016 09:11 #2 by babynus
It is because issue is in /Model/Parameter.php, not /files/config/parameter.php.
It seems you have a /tool/parametersLocation.php file, but it does not contain correct $parametersLocation var or this does not fit parameters.php file location.
Try and delete /tool/parametersLocation.php and try again.
NB : I don't understand the "locally installation" you report. Are these installed modules ?
ProjeQtOr just needs to be unzipped on a PHP server web directory...
28 Mar 2016 12:45 #3 by Sylvain
Well, I try to install ProjeQTor In my computer, with web service MAMP
My computer is old.
I change in PHP.ini the delai for execute script.
30s => 480s.
I try to add some time... and i say you what append
The data base is OK, but need long time to be contructed
so, i try with xamp soon and i'm coming back here toreport the result...
Objective :
  1. Learn to use Projeqtor
  2. See how to install for dedicated server
  3. Use ProjeQTor for my project
28 Mar 2016 15:16 #4 by Sylvain
Sorry for double post...
Well, all are good.
I installed xamp for windows 7
I adapted 3 things in php.ini
  • Mysql extension
  • imap extension
  • max_input_vars = 4000
Version of :
  • PHP : 5.6.15
  • Apache : 2.4.17 (win32)
  • DB engin : MariaDB 10.1.10
I don't the raison that block installation with server MAMP
For me, issue is closed.
I expect that serve for everybody ;)
Sylvain
