ProjeQtOr free project management software - I keep being disconnected - ProjeQtOr
26 Feb 2016 01:04 #1 by joseph
I finally got Projeqtor installed and running.
But, with in about 2-3 minutes of looking around the system, I keep getting told that I am disconnected.
Ideas of what this could be?
Joe
26 Feb 2016 09:06 #2 by babynus
Replied by babynus on topic I keep being disconnected
Check log file.
26 Feb 2016 23:49 #3 by joseph
Replied by joseph on topic I keep being disconnected
Mind pointing me to where the log file is?
Other point, when I was logging in I was warned the the value of something in the php.ini was too low.
"max_input_vars=1000 is too small - value should be at least 2000, 4000 recommended - check your php configuration (php.ini)"
I looked in the php.ini file, and did not find the value to change. Could this be the issue?
This might be part of the cause, maybe? Or not?
Thanks for help.
Joe
27 Feb 2016 11:19 #4 by babynus
THe log file is where you defined it during configuration.
Default location is /files/logs ... one file per day.
But you can alos access log files through Administration screen
The max_input_var message is just a warning, not a blocking point.
It may come to be an issue only when your database groes up, and only on some screens (Real work allocation for instance).
So it is not source of issue.
Check for log file and post it here.
03 Mar 2016 01:06 #5 by joseph
I disconnect so quickly that I am not able to view the logs in the software interface.
But, when I look at the log files via FTP, the last entry is that the "admin" user logged in. Nothing more. No further entries.
Ideas on where else we can look?
Joseph
04 Mar 2016 20:01 #6 by babynus
For instance with Chrome, open dev tools [F12], then go to console tab.
Check the "preserve log" option.
Then you'll be able to see console logs (and possibly errors) thought pages.
