ProjeQtOr free project management software - Projects in stand-by mode - ProjeQtOr
25 Feb 2016 10:40 #1 by Iaurkano
hi babynus,
Is it possible to put a project in stand-by mode. The need is to free all ressource assigned on this project, when the project is intand by mode.
in fact, sometimes, we work on project plan, ressource assignement, etc. , and a change of priority happends. so the project is suspended, until an unknown date. it will done after but we dont kown when . In this case it should be great to put project in stand-by mode, to keep the plan, but it's needed that this project does not impact ressource avaibility for other one's.
i don't known if i'm clear, i hope, i'm .....
Thank's a lot and
Thank's for your work.
25 Feb 2016 14:36 #2 by richard.pare
You can close project affectation for these resources.
Check box "Close" in "affectation" dialog box.
You can change project affectation period.
You can fix project planning.
25 Feb 2016 22:01 #3 by babynus
Replied by babynus on topic Projects in stand-by mode
beszt way is to plan the project with plan start date very far inthe future (01/01/2050) for instance.
then check the fix planning ckeckbox and put in a specifc status.
26 Feb 2016 09:02 #4 by Iaurkano
Replied by Iaurkano on topic Projects in stand-by mode
Ok i will try.
thank's for your help.
