ProjeQtOr free project management software - Which it is a product ProjeqtOr and what is its function? - ProjeQtOr
16 Feb 2016 22:40 #1 by dabernate
Good afternoon
16 Feb 2016 23:47 #2 by babynus
Sorry I don't understand the Question.
Could you explain ?
17 Feb 2016 14:28 - 17 Feb 2016 14:30 #3 by dabernate
What is the function in the module product?
it's located Environment / Product
Last edit: 17 Feb 2016 14:30 by dabernate.
17 Feb 2016 14:58 #4 by babynus
Product is what the project works for.
A project is designed to build somthing.
It can be :
- an industrial Product (something like a prototype, ProjeQtOr is not designed to follow up production of products)
- an application (for IT projects)
- a service
In ProjeQtOr, it is called a Product.
So you define product, versions of product, and link version of product to project.
Then you're able to indicate on which version of product an activity stands for, or a requirement is valid for.
And you can then have version follow-up (in reports).
If you want an simple example, go to track.projector.org.
There is one only product : ProjeQtOr.
Every version of projeqtor is recorded as a version.
Every ticket is linked to a version.
This is ProjeQtOr roadmap :woohoo:
