ProjeQtOr free project management software - [SOLVED] DataGrid and ChangingHistory topics - ProjeQtOr
01 Feb 2016 10:19 - 01 Feb 2016 10:23 #1 by keloniton
Hello Dear Mr babyrus
I will be thanksfull if you guide me about following questions:
1- there is a Grid as dojox.grid.DataGrid dojo widget in most of pages. I want to change the date formats from gregorian to Jalali in these grids.
A. Where is the related source code?
B. Does Dojox.Grid.DataGrid support Persian calander?
C. Do you have any idea how i can change the dates shown in that. I have the related fucntion to convert gregorian calander to Jalali. I do not know how to access the date sector of the grid objectstore.
2- There is a changing historry in button of some pages. The calander format is gregorian. I want to change it also.
D. Where is the related source code?
Thanks in advance
Last edit: 01 Feb 2016 10:23 by keloniton.
01 Feb 2016 13:40 #2 by babynus
1.A /view/js/projeqtorFormatter.js function formatDate()
1.B no need, you have to format it yourself in formatDate()
1.C All you have to do is change formatDate()
2.D /tool/html.php function htmlFormatDate()
Both functions should do the same, one in JavaScript (for dbGrid) one on PHP (for history and other displayed dates)
03 Feb 2016 11:34 - 03 Feb 2016 13:32 #3 by keloniton
I edited the file as follows:
//first i added a function to convert gregorian calendar to jalali as follows (I have tested this code, this works
Date.jalaliConverter = {};
Date.jalaliConverter.gregorianDaysInMonth = new Array(31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31);
Date.jalaliConverter.jalaliDaysInMonth = new Array(31, 31, 31, 31, 31, 31, 30, 30, 30, 30, 30, 29);
Date.jalaliConverter.div = function (a, b) {
return Math.floor(a / b);
Date.jalaliConverter.remainder = function (a, b) {
return a - Math.floor(a / b) * b;
Date.jalaliConverter.gregorianToJalali = function (g) {
var gy, gm, gd;
var jy, jm, jd;
var g_day_no, j_day_no;
var j_np;
var i;
gy = g[0] - 1600;
gm = g[1] - 1;
gd = g[2] - 1;
var div = Date.jalaliConverter.div;
var remainder = Date.jalaliConverter.remainder;
var g_days_in_month = Date.jalaliConverter.gregorianDaysInMonth;
var j_days_in_month = Date.jalaliConverter.jalaliDaysInMonth;
g_day_no = 365 * gy + div((gy + 3), 4) - div((gy + 99), 100) + div((gy + 399), 400);
for (i = 0; i < gm; ++i)
g_day_no += g_days_in_month;
if (gm > 1 && ((gy % 4 == 0 && gy % 100 != 0) || (gy % 400 == 0)))
/* leap and after Feb */
++g_day_no;
g_day_no += gd;
j_day_no = g_day_no - 79;
j_np = div(j_day_no, 12053);
j_day_no = remainder(j_day_no, 12053);
jy = 979 + 33 * j_np + 4 * div(j_day_no, 1461);
j_day_no = remainder(j_day_no, 1461);
if (j_day_no >= 366) {
jy += div((j_day_no - 1), 365);
j_day_no = remainder((j_day_no - 1), 365);
for (i = 0; i < 11 && j_day_no >= j_days_in_month; ++i) {
j_day_no -= j_days_in_month;
jm = i + 1;
jd = j_day_no + 1;
return new Array(jy, jm, jd);
//Then i simply edited the formatDate(date) function as follows
function formatDate(date) {
if (!date) {
return '';
var month = date.getMonth() + 1;
var year = date.getFullYear();
var day = date.getDate();
month = (month < 10) ? "0" + month : month;
day = (day < 10) ? "0" + day : day;
var y= Date.jalaliConverter.gregorianToJalali (new array [year,month,day]);
year = y[0];
month = y[1];
day = y[2];
return year + "-" + month + "-" + day;
But the shown girds ( i my self checked project page) does not change to jalali. Do you have any idea ?
Last edit: 03 Feb 2016 13:32 by keloniton.
03 Feb 2016 14:52 #4 by babynus
The way you do it seems correct, but your gregorianToJalali does not seem to return what you expect.
Jest tests it unitary.
03 Feb 2016 17:34 #5 by keloniton
It is so strange. I changed the convertor code. I made a sample file which worked. here is the sample source.
<!DOCTYPE HTML>
<html>
<head>
<title>Untitled 2</title>
<script>
//Converting the gregorian to Jalali date
JalaliDate = {
g_days_in_month: [31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31],
j_days_in_month: [31, 31, 31, 31, 31, 31, 30, 30, 30, 30, 30, 29]
JalaliDate.gregorianToJalali = function(g_y, g_m, g_d)
g_y = parseInt(g_y);
g_m = parseInt(g_m);
g_d = parseInt(g_d);
var gy = g_y-1600;
var gm = g_m-1;
var gd = g_d-1;
var g_day_no = 365*gy+parseInt((gy+3) / 4)-parseInt((gy+99)/100)+parseInt((gy+399)/400);
for (var i=0; i < gm; ++i)
g_day_no += JalaliDate.g_days_in_month;
if (gm>1 && ((gy%4==0 && gy%100!=0) || (gy%400==0)))
++g_day_no;
g_day_no += gd;
var j_day_no = g_day_no-79;
var j_np = parseInt(j_day_no/ 12053);
j_day_no %= 12053;
var jy = 979+33*j_np+4*parseInt(j_day_no/1461);
j_day_no %= 1461;
jy += parseInt((j_day_no-1)/ 365);
j_day_no = (j_day_no-1)%365;
for (var i = 0; i < 11 && j_day_no >= JalaliDate.j_days_in_month; ++i) {
j_day_no -= JalaliDate.j_days_in_month;
var jm = i+1;
var jd = j_day_no+1;
return [jy, jm, jd];
//A function just like projeqtorFormatter.js function with 3 alerts to be sure about the values of convered year, month and day
if (!date) {
return '';
var y= JalaliDate.gregorianToJalali(year,month,day);
year = y[0];
month = y[1];
day = y[2];
alert (year.toString());
alert (month.toString());
alert (day.toString())
</script>
</head>
<body>
<button type="button" onclick="formatDate(new Date(2016,01,01));"> show date!</button>
</body>
</html>
As the button is clicked, The date is converted and shown by formatDate function. I just pasted the same code in projeqtorFormatter.js. The interesting point is that there is no alert message. Does it mean that FormatDate function probably is not correctly loaded when the grid is displayed. I am really confused. I will appreciate if you help me with that.
03 Feb 2016 17:50 #6 by babynus
So it may be some javasript cache issue.
