ProjeQtOr free project management software - [SOLVED] Priority on projects ,subprojects and activities - ProjeQtOr
21 Jan 2016 10:56 #1 by El Wallos
Hi Babynus
You answered me about priority on projects and subprojects but I did some tests and I'm not sure how to interpret the result.
My results were: (Sub= sub project, act=activities)
- If priority is medium (500) on all (project, subproject and activities), the lower WBS is planned first
- Project A (300) , Sub (500) , Act (500) and Project B (500), SUb (500) Act (300), the activity of project B is planned first, so the priority on activities is more important than priority on Project.
- Project A (300) , Sub (500) , Act (500) and Project B (500), SUb (500) Act (400), the activity of project B is planned first, I don't understand why?
Is it necesary to replan to take in charge the update of the priority even if "automatic run plan" is enabled?
Could you explain me the relation about priority between project, subproject and activities? How the priority is taken to create the planning?
22 Jan 2016 19:02 #2 by babynus
Thing on priority as global like [Priority on project].[Priority on activity]
priority is 500.500
priority is 500.300
Activity on B is planned first !
Priority on top project is not taken into account, only priority on project of activity.
25 Jan 2016 10:28 #3 by El Wallos
Thanks Babynus, it takes sense...that's why I need to change the priority of the sub project (if exists). :woohoo:
Thanks a lot for sharing your knowledge.
25 Jan 2016 17:45 - 25 Jan 2016 17:46 #4 by El Wallos
El Wallos wrote: Is it necesary to replan to take in charge the update of the priority even if "automatic run plan" is enabled?
Could you confirm me ?
Last edit: 25 Jan 2016 17:46 by El Wallos.
27 Jan 2016 17:36 #5 by babynus
Yes and no.
Automatic planning runs only on Gantt view.
If you change priority on Activity view, you have to run planning manually.
But if you do in on Gantt view, planning should be recalculated automatically.
29 Jan 2016 13:34 #6 by El Wallos
Thanks, I have a better understanding about how to use the priority on ProjeQtOr.
