ProjeQtOr free project management software - [SOLVED] Gmail SMTP Won't connect - ProjeQtOr
20 Jan 2016 22:27 #1 by cbarden
I've tried this using a number of different server addresses e.g. tls://smtp.gmail.com 465 587
My firewall is disabled.
I'm running v5.2.1 and have never had success with the email configuration.
I have a different application using smtp.gmail.com and 465 on the same machine with no issues.
I'd love to use this software but will have to move on if you can't get the email to work.
Error follows:
SMTP Server : smtp.gmail.com
2016-01-20 16:14:05.137 ***** ERROR ***** SMTP Port : 465
2016-01-20 16:14:05.138 ***** ERROR ***** Mail stored in Database : #38
2016-01-20 16:14:05.138 ***** ERROR ***** PHPMail error : SMTP connect() failed. github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
2016-01-20 16:14:05.139 ***** ERROR ***** PHPMail debug :
22 Jan 2016 18:51 #2 by babynus
Replied by babynus on topic Gmail SMTP Won't connect
Google has changes security constraints.
When connecting from new apllication, default behavior is now to block connection.
You may have a notification in your gmail account. You must tretreive this notification and follow instructions to allow connections.
25 Jan 2016 17:52 #3 by cbarden
Replied by cbarden on topic Gmail SMTP Won't connect
I've tried a few other smtp servers with the same outcome. Connection is always refused.
Does this function work or not?
27 Jan 2016 17:37 #4 by babynus
Yes works fine.
I use it every day ;)
27 Jan 2016 21:03 #5 by cbarden
I appreciate your help and was hoping that this would be the solution we would be implementing.
Without a working email function, it's not going to happen.
Small world -
28 Jan 2016 09:09 #6 by babynus
It's only a matter of configuration.
Depending on smtp provider, configuration may differ, but I did not hear about someone not succedding in having it work at last.
