ProjeQtOr free project management software - [SOLVED] Project's status and Activities can't be changed - ProjeQtOr
08 Jan 2016 12:20 - 08 Jan 2016 15:04 #1 by SABIR
Users can't change the status of projects and Activities. Only Admin can
Thank you for your help
Last edit: 08 Jan 2016 15:04 by SABIR.
08 Jan 2016 21:24 #2 by test31
Can you add a screen copy?
Are users mentionned affected to the project?
With which role?
10 Jan 2016 18:49 #3 by babynus
Also check workflow : maby only admin is allowed to change current status.
12 Jan 2016 11:20 #4 by SABIR
In fact , the problem was at the workflow level, only the administrator has access to change the status .
I have authorized the other users , now it works .
thanks for your help
