ProjeQtOr free project management software - [SOLVED] Problem LDAP Connexion - ProjeQtOr
30 Dec 2015 16:03 #1 by fbinoust
I can activate LDAP authentification in Projeqtor
The server is Windows 2012
WampServer Version 2.5
The version of Projeqtor is 5.1.4
Paramètres de gestion Ldap
connexion via LDAP : OUI
base dn LDAP : DC=entrep,DC=local
serveur LDAP : 192.168.1.1
port LDAP : 389
version LDAP : 3
utilisateur LDAP : CN=ADBROWSER,DC=entrep,DC=local
mot de passe LDAP : xxxxxxxxx
filtre pour utilisateur : sAMAccountName=%USERNAME%
profil par défaut pour les utilisateurs Ldap : Invité
message à la création d'un utilisateur Ldap : Alerte interne & mail
In logs the message is
2015-12-30 15:46:46.579 ***** ERROR ***** Ldap not installed on your PHP server. Check php_ldap extension or you should not set $paramLdap_allow_login to "true"
2015-12-30 15:46:46.579 ===== TRACE ===== Error contacting Ldap for user 'adminsal'
In my php.ini, I've got
extension=php_ldap.dll
[ldap]
; Sets the maximum number of open links or -1 for unlimited.
ldap.max_links = -1
php_ldap.dll exist
With LDAP Browser I can connect to my LDAP base
Is someone can help me ?
30 Dec 2015 16:18 - 30 Dec 2015 16:18 #2 by babynus
Replied by babynus on topic Problem LDAP Connexion
Can you please post a php info ?
To get this, create a php file (for instance info.php) with
<?php phpinfo(); ?>
Then call it from browser.
Last edit: 30 Dec 2015 16:18 by babynus.
30 Dec 2015 16:47 #3 by fbinoust
Replied by fbinoust on topic Problem LDAP Connexion
You will find the configuration in the file config php.pdf
30 Dec 2015 17:14 #4 by babynus
The ldap module does not appear in the phpinfo.
So sure issue is due to incorrectly loaded ladap module.
Check for errors in php log file (or in apache error log file).
Also be sure to restart php.
Issue may be due to ldap dll version not corresponding to php version.
30 Dec 2015 17:31 #5 by fbinoust
How can I do to find the good version
30 Dec 2015 19:51 #6 by babynus
Maybe upgrade to a most recent WAMP stack.
