ProjeQtOr free project management software - How to modify project expenses ? - Page 2 - ProjeQtOr
24 Dec 2015 18:54 #7 by babynus
This can happen if project has sub-project and validate expense is defined at sub-project.
If it's not your case, please provide print screen. It may be an unexpected behavior.
24 Dec 2015 20:52 #8 by test31
I found all these datas are managed in table 'planningelement', and for the project with problem, field ValidatedCalulated was '1'. I modified it in database and can now modify validated expenses.
I don't know how I managed to get this (since I don't have any sub-project, but perhaps I had during tests?) and don't succed to reproduce. If I get it again, I will create a new post then.
24 Dec 2015 21:26 #9 by test31
It seems that if you attach a sub-project to project P, field then becomes grey (which is normal).
But if then you attach sub-project to another project, project P still stay with field in grey (which is no longer OK).
25 Dec 2015 20:56 #10 by babynus
Issue recorded as Ticket #1904
