ProjeQtOr free project management software - Can't create Activity as project leader - ProjeQtOr
23 Dec 2015 09:04 #1 by tjaeckle
Hello!
I'm evaluating this interesting tool and have following problem:
As admin I added a user with profile "project member".
I created a project where I added this user under Affectations with the profile "project leader".
As much as I understood the manual, the user should now be able to create sub projects and activities for this special project.
So I logged in as this user. If I go to "Follow-up -> Planing", select the project and use "Create a new item" two different things happen:
* Creating a project: Message "You don't have rights to access this Project." appears.
* Creating an activity: The menu for the new activity appears, but all fields are grayed out, so no input is possible. Also the buttons for saving, ... are disabled.
What is my mistake?
I'm using version 5.1.5
Thanks in advance,
Thomas
23 Dec 2015 09:51 #2 by babynus
This is a known limitation.
When you create a project, as long as the project itself is not defined, only default profile is taken into account to give creation rights.
It will be an improvement to give possiblity to create sub-project, forcing project list (for is-sub-project-of) to list of projects the user has rights to create projects.
This is a real issue. Origin is same as above : as long as project is not defined, it is not possible to give rights to create...
An improvement will be brought. Ticket #1903 recorded.
As a workaround, you should work the other way round : give as default profile the profile that will give more rights (Project Leader) and affect as project member on projects where user is only a project member.
