ProjeQtOr free project management software - [SOLVED] Gestion of Ticket - ProjeQtOr
02 Dec 2015 13:31 - 02 Dec 2015 14:22 #1 by ericzen
Gestion of Ticket was created by ericzen
I would like to know, if it's possible to have those functionalities :
- create automatically a new ticket when you receive a mail on the address This email address is being protected from spambots. You need JavaScript enabled to view it.
- updating of a ticket when their his a response to the address This email address is being protected from spambots. You need JavaScript enabled to view it.
Other question : I can't launch Cron directly in Projeqtor, but i can launch it directly on my lodging. What is the file which is launch by cron ?
Thanks for your help
Ericzen
Last edit: 02 Dec 2015 14:22 by ericzen.
03 Dec 2015 11:19 #2 by babynus
Replied by babynus on topic Gestion of Ticket
No, but it's planned in Ticket #1048.
The hard part will not be to retreive the email but determine to wich project to attach it ...
Yes, it works.
You have to configure IMAP parameters.
The response is stored as new note on ticket.
Please explain a bit better.
I can't launch Cron directly in Projeqtor => what happens when you try ?
i can launch it directly on my lodging => can you explain what you do and what you get ?
What is the file which is launch by cron => it's not a script file, it is an object :(
NB : please open new thread for this new topic, and avoid dealing with several subject on a single post.
04 Dec 2015 16:25 #3 by ericzen
Replied by ericzen on topic Gestion of Ticket
For the first reponse, is it possible to affect automatically to a project by defaut associated to a contact. After, the manager can reaffect the demand to the right project.
For the second question : I don't know how i can find the IMAP Server Address like you define for GMAIL. An idea ?
For the last demand, Solved by changing my lodger and have my own server.
04 Dec 2015 19:12 #4 by babynus
So have to define a default project (and this should be not mandatory), as possibly contact could be affected to several projects (so this link is not valid).
So there are many cases when Project will not be determined, and it is not possible to create a Ticket without a project (nobody would see it except admin, who does not intend to manage tickets).
In global parameters.
05 Dec 2015 16:12 #5 by ericzen
OK,
I use Projeqtor like this :
- Projects define for an entity with multiple projects
- One project name's Assistance for open tickets. Then i can affect ticket by project or stand in Assistance project to define if it's an assistance in the helpdesk contract or if it's a new project.
That's why i purpose this solution to manage new ticket from entering mail.
For the second point, i didn't arrive to configure to update automatically ticket by mail. you can see my parameters in this attach file.
Need i create a user name helpdesk ? Is my Imap Server Address that not good and how can verify if it's the good value ?
Thanks for your help.
06 Dec 2015 17:45 #6 by babynus
I understand your way of working, but target solution must ba available for everybody.
Configuration seems correct.
But maybe you just did not start CRON : it is the CRON that will reguliarly check incoming mails.
Start CRON in Administration screen...
If it still does not work, check Log file, you may have hints.
