ProjeQtOr free project management software - Teams are not working at fully time on project 4 - ProjeQtOr
10 Nov 2015 17:16 #1 by El Wallos
Hi all
I explain my doubt; I have one cyclic task (planification = regular between two dates) (70% of a day time) and the other 30% are dedicated to all projects.
For example, for one ressource, I have 4 projects. So, how can I assign the 30% for these 4 projects?
My solutions are:
- 30% / 4 = 7.5% ressource affected on each project (problem: what's happen if today, I have 6 projects, I need to update all my affectations?)
- 30% on all activities ???
My two solutions are not optimal, do you have a better solution?
12 Nov 2015 12:54 #2 by El Wallos
16 Nov 2015 10:09 #3 by El Wallos
16 Nov 2015 17:54 #4 by babynus
I would set 100% to all projects...
They it is priorities, dependencies that will define when projects are planned.
16 Nov 2015 17:58 #5 by El Wallos
100% or 30%??? because my bandwith for project is only 30%
16 Nov 2015 18:43 #6 by babynus
100%
Yes
I confirm 100%
Regular between dates will be planned first (it is one of the priority rules for planning) and other projects will only use left availability, so affectation rate at 100% will use the 30% left.
