ProjeQtOr free project management software - PREDECESSOR ELEMENT - ProjeQtOr
PREDECESSOR ELEMENT
06 Nov 2015 02:28 #1 by pavilonsxx
Hi everyone,
Let me ask the predecessor element. If I choose it to work, the mandatory implementation of previous work and then to work it. Thus, there are no warning? when I made that work without making work mandatory before it. I have not seen in projeqtor warning.
Thanks!
06 Nov 2015 09:17 #2 by babynus
Replied by babynus on topic PREDECESSOR ELEMENT
Sorry, I don't understand the purpose of your post.
Is it a question or an issue ?
Please explain.
Try and detail use case.
06 Nov 2015 09:26 - 06 Nov 2015 09:34 #3 by pavilonsxx
Replied by pavilonsxx on topic PREDECESSOR ELEMENT
I mean what is the predecessor element?
I have the task A, task B, Task A is the predecessor of Task B. As I understand the task A is performed completed. Next will perform the task B. If task A unfinished will not be able to perform task B. Thus correct?
Last edit: 06 Nov 2015 09:34 by pavilonsxx.
06 Nov 2015 09:28 #4 by babynus
Predecessor is task that must be finished before current can start.
This is a constraint in planning calculation, but not on real work input.
06 Nov 2015 09:40 #5 by pavilonsxx
Please just give me constraints, I have tested, but I did not see the warning dialog box, So how to see the constraints that i enter in real result allocation work?
08 Nov 2015 12:15 #6 by babynus
The constraints have no effect on real work allocation.
They are here to plan work, and are taken into account in planning calculation.
But reality is always different from planned, and constraitns have no effect on reality.
