ProjeQtOr free project management software - [SOLVED] Validate Real Work Allocation - Page 3 - ProjeQtOr
02 Nov 2015 10:36 #13 by El Wallos
I don't know if it is a bug but with IE (only IE, with Chrome it is working fine) , when a ressource want to submit his Real Work Allocation, a disconnection is suggested, is it normal? or I need to able a parameter on IE?
02 Nov 2015 10:43 #14 by babynus
I cannot reproduce.
Looking at your screenshot I guess you are in "IE7 compatibility" mode (no transparency on buttons shows non CSS3 compatibility).
I think issue come from this compatibility mode.
V5.1 fixes this by forcing edge mode.
02 Nov 2015 16:20 #15 by El Wallos
Thanks for reply,
I use IE 8.0.76. I will upgrade to 5.1 ASAP.
