ProjeQtOr free project management software - [SOLVED] Administrative project activities not showing up in Gantt - ProjeQtOr
28 Oct 2015 13:38 #1 by papjul
We would like to foresee if too many resources are taking their Christmas holidays at the same time so we created an administrative with a "days off" activity (as you suggested in another topic) and everyone input their holidays on Real Work Allocation.
Unfortunately, when we select the project Administrative on top left of the application, and we go to Resource planning screen, I have the message "No data to display". Were these activities hidden on purpose? How can I disable that?
Thank you,
28 Oct 2015 15:38 #2 by babynus
Administrative projects are not displayed in Gant chart.
It is designed this way : administrative project are not "planned"
Resource planning would not halp you for what you expect : you would just see a bar from first day out to last day out, even if resouce is working in between.
Use reports for what you expect.
02 Nov 2015 09:48 #3 by papjul
What is the report to use for that case?
02 Nov 2015 09:54 #4 by papjul
Okay, I found it (planning -> monthly something, for the record).
Solved, thank you!
