ProjeQtOr free project management software - Différence between "charge" and "durée" - ProjeQtOr
19 Oct 2015 13:30 #1 by El Wallos
Hi all,
I have a doubt when I create a task, I don't understand the difference between "charge" and "durée"? In which case I need to use each one?
PD: I know the difference between "charge" and "délai" but not between "charge" and "durée"
Thanks for sharing your knowledge.
Martin
The following user(s) said Thank You: chenevieredd
19 Oct 2015 14:24 #2 by babynus
"Charge" (work) is quantitiy of Work.
"Durée" (duration) is delay, in open days.
If 2 resources share 20 days of work (charge) to do on a task, with equal repartition (10 days each), duration (durée) will be 10 days, and delay will be 2 weeks (14 days or 12 days if task starts on monday).
19 Oct 2015 14:47 #3 by El Wallos
Thanks for reply.
If I work with ASAP planification method, I just fill "durée" field and it is enough.
So, in which case can I use "charge"?
Martin
19 Oct 2015 15:07 #4 by babynus
NO.
Duration is informative unless you choose "fixed duration" planning mode for the task.
ALWAYS
You should always define work as ProjeQtOr is work driven : planning is calculated from work data, and not from duration. It is the only way to have realistic planning.
Imagine you have a resource working 3 days on Task A and 2 days on tasks B, and tasks don't have a dependency (resource can work indenpendently on any task). If you work with duration, global duration of the project is 3 days (the longest duration). But if you work on work, total duration of project is 5 days.
This is a simple example, but imagine working with 50 resources, working on 100 tasks, some with dependencies, some not, and some resources sharing some tasks, .... Working with duration will not help. Working with work will compute realistic planning.
Moreover if you have 2 tasks, each with duration of 5 days, task A is complete, task B half completed (50%). What is global progress of project ?
You should say 75% (50% for task A, 25% for task B).
But now if I say that task A is a 0,1 day per day task (some management for instance) and task B is full time for 2 resources, real progress is 52% = (0.5+5)/10.5.
And if resource estimate that they need 4 extra work days to end task B (reestimate left work), then progress is just 38% = (0.5+5)/14.5
It is work driven (also called effort driven) planning.
19 Oct 2015 16:26 #5 by El Wallos
It takes sense but when I update the new value on "charge" field (ex: 7 days) without fill "durée" (with ASAP planification), the Grantt project doesn't update the Gantt planing as I expect (a task with 9 days with the week end).
Do you have any documentation with a case study? Just to do it step by step and understand better how your software works?
19 Oct 2015 16:48 #6 by babynus
Just because you did not run planning calculation : planning is not automatically calculated as it is considered as a management act.
Use button on top left of planning view (with the 2 gears)
