ProjeQtOr free project management software - [SOLVED] Project Menu - ProjeQtOr
17 Oct 2015 14:59 - 17 Oct 2015 15:53 #1 by ericzen
Project Menu was created by ericzen
Sorry if someone has ever done this demand, but i haven't found the answer on the forum yet.
I've created two projects and three users. I want user one sees all project and the others only one.
When i 'm login with the users two who is attached to project one, i have only data for project one => that's what i want. But if i click on the project menu at the bottom left of the screen, i can see a list of all project present in the database. I would like there is only the project attach to my user listing.
How can i do that ?
I'm in version 5.0.6 of projeqtor. My user is external project leader.
Thanks for your help
Ericzen
Last edit: 17 Oct 2015 15:53 by ericzen.
17 Oct 2015 16:35 #2 by babynus
Replied by babynus on topic Project Menu
So let me summurize your use case, and correct me if I'm wrong.
You have 2 projects P1 and P2.
You have one User U1, affected to project P1 and not affected to P2.
Default profile of U1 is external project leader.
P2 is not subproject of P1 nor P1 subproject of P2.
When connected, U1 sees items (activities, tickets, ...) of P1, but none of P2. (that's exactly what you expect and how ProjeQtOr works)
On Project screen, U1 sees P1 and P2 : is that your issue ?
So :
- Check Project Type : Template and Administrative projects are special ones that you should not use in your case (they give wide visibility)
- Try disconnect / reconnect (sometimes access rights are not updated until reconnection, so if you once gave access to U1 to P2, he may see P2)
18 Oct 2015 14:48 #3 by ericzen
Replied by ericzen on topic Project Menu
For your comprehension, i've joined an exemple of what i need
18 Oct 2015 16:06 #4 by babynus
What is default profile user users U1 and U2 ?
(in Users screen)
18 Oct 2015 16:49 #5 by ericzen
They are both external project leaders
19 Oct 2015 13:04 - 19 Oct 2015 13:05 #6 by babynus
External Project Leaders and External Project Members are "Reader+" on Documents, Requirements, Test Cases and Test Sessions.
This gives them global visibility on all these items, whatever the project, and so lists all project in selector.
Just set acces mode to "Reader" will fix this issue.
(patch will be applied in V5.1, Ticket #1819)
Last edit: 19 Oct 2015 13:05 by babynus.
