ProjeQtOr free project management software - [SOLVED] Resources not displayed in planning view - ProjeQtOr
29 Sep 2015 14:37 #1 by MWN6700
When selecting the "planning view" and displaying the column "resources", the column resources remains empty. (However I have assigned several resources on the task).
What did I wrong ?
(using V5.0.5)
29 Sep 2015 19:41 #2 by stephane.pelletier
looks like only initials of resources are presented in this view. Are you sure you have defined intials for all your resources?
29 Sep 2015 19:57 #3 by babynus
Stephane is right.
By default, resource are displayed as their initials. So if not set, nothing is displayed.
You can change this in gobal parameters, to select display of name instead of initials, but may lead to a real mess if names are long...
The following user(s) said Thank You: MWN6700
30 Sep 2015 11:14 #4 by MWN6700
Ok I found it.
I didn't check the flag "show ressources" on the top right.
Thank you for the prompt support.
Time to create page: 0.247 seconds
