ProjeQtOr free project management software - Module IMAP is not available - ProjeQtOr
04 Sep 2015 13:38 #1 by iladu
Hallo!
I'm trying ProjectQtor on a server whitout IMAP module : when i try to do the first access (user admin password admin) i have the error message "Module IMAP is not available - impossible to configure ProjeQtOr to retreive notes from received emails" . I don't want use the mail...there is a way to use the application whitout the imap module?
Thank's
Ila
04 Sep 2015 14:07 #2 by babynus
Yes,
This message is just a warning, to inform you that corresponding to mis-configuration, you won't be able to use the corresponding feature.
You can continue without worry.
04 Sep 2015 14:17 #3 by iladu
Replied by iladu on topic Module IMAP is not available
I can't login .... i've also the message "ERROR : An error occurred on 2015-09-04 at 14:16:31"
04 Sep 2015 14:25 #4 by babynus
Post here error you'll find in log file
04 Sep 2015 14:37 #5 by iladu
:ohmy: :ohmy: :ohmy: :ohmy: :ohmy:
2015-09-04 14:16:24.771 ===== TRACE ===== Login error for user ''
2015-09-04 14:16:31.718 ===== TRACE =====
2015-09-04 14:16:31.718 ===== TRACE ===== =====================================
2015-09-04 14:16:31.718 ===== TRACE ===== DataBase actual Version =
2015-09-04 14:16:31.718 ===== TRACE ===== ProjeQtOr actual Version = V5.0.5
2015-09-04 14:16:31.719 ***** ERROR ***** ERROR *****
2015-09-04 14:16:31.719 ***** ERROR ***** on file '/membri/monitoratti/projeqtor/tool/projeqtor.php' at line (2510)
2015-09-04 14:16:31.719 ***** ERROR ***** cause = set_time_limit() has been disabled for security reasons
2015-09-04 14:25:50.313 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:50.313 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:50.313 ***** ERROR ***** Strack trace :
2015-09-04 14:25:50.313 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:50.313 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:50.313 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:50.313 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:50.313 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:50.313 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/view/main.php:37]
2015-09-04 14:25:50.313 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:50.314 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:50.314 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:50.314 ***** ERROR ***** Strack trace :
2015-09-04 14:25:50.314 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:50.314 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:50.314 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:50.314 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:50.314 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:50.314 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/view/main.php:37]
2015-09-04 14:25:50.314 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:50.315 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:50.315 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/view/main.php:37]
2015-09-04 14:25:50.315 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:50.315 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:50.315 ***** ERROR ***** Strack trace :
2015-09-04 14:25:50.315 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:50.315 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:50.315 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/view/login.php:62]
2015-09-04 14:25:50.316 ***** ERROR ***** #3 include called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:190]
2015-09-04 14:25:50.316 ***** ERROR ***** #4 require_once called at [/membri/monitoratti/projeqtor/view/main.php:37]
2015-09-04 14:25:50.320 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:50.320 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:50.320 ***** ERROR ***** Strack trace :
2015-09-04 14:25:50.320 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:50.320 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:50.320 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/view/login.php:181]
2015-09-04 14:25:50.320 ***** ERROR ***** #3 include called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:190]
2015-09-04 14:25:50.320 ***** ERROR ***** #4 require_once called at [/membri/monitoratti/projeqtor/view/main.php:37]
2015-09-04 14:25:50.321 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/view/login.php:204]
2015-09-04 14:25:50.321 ***** ERROR ***** #3 include called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:190]
2015-09-04 14:25:50.321 ***** ERROR ***** #4 require_once called at [/membri/monitoratti/projeqtor/view/main.php:37]
2015-09-04 14:25:50.321 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:50.321 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:50.321 ***** ERROR ***** Strack trace :
2015-09-04 14:25:50.321 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:50.321 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:50.321 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/view/login.php:232]
2015-09-04 14:25:50.322 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:50.322 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:50.322 ***** ERROR ***** Strack trace :
2015-09-04 14:25:50.322 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:50.322 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:50.322 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/view/login.php:238]
2015-09-04 14:25:50.322 ***** ERROR ***** #3 include called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:190]
2015-09-04 14:25:50.322 ***** ERROR ***** #4 require_once called at [/membri/monitoratti/projeqtor/view/main.php:37]
2015-09-04 14:25:51.005 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.006 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.006 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.006 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.006 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.006 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.006 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.006 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.006 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.006 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.006 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.007 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.007 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.007 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.007 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.007 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.007 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.007 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.007 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.007 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.007 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.008 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.008 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.028 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.028 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.028 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.028 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.028 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.028 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.029 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.029 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.029 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.029 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.029 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.029 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.029 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.029 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.029 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.030 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.030 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.030 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.030 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.030 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.030 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.030 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.030 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.030 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.030 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.051 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.051 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.051 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.051 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.051 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.051 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.051 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.051 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.051 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.052 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.052 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.052 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.052 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.052 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.052 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.052 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.052 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.052 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.052 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.053 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.053 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.053 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.053 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.053 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.053 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.053 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.053 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.053 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.073 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.073 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.073 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.074 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.074 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.074 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.074 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.074 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.074 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.074 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.074 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.074 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.074 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.075 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.075 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.075 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.075 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.075 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.075 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.075 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.075 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.075 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.075 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.096 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.096 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.096 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.096 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.096 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.096 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.096 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.096 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.096 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.097 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.097 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.097 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.097 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.097 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.097 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.097 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.097 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.097 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.098 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.098 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.098 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.098 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.098 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.098 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.098 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.098 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.098 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.098 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.119 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.119 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.119 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.119 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.119 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.119 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.119 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.119 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.119 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.120 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.120 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.120 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.120 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.120 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.120 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:25:51.120 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.120 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.120 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.120 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:25:51.121 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:25:51.121 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:25:51.121 ***** ERROR ***** Strack trace :
2015-09-04 14:25:51.121 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:25:51.121 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:25:51.121 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:25:51.121 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:25:51.121 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:25:51.121 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/saveDataToSession.php:30]
2015-09-04 14:26:01.855 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.855 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.855 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.855 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.855 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.855 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:01.855 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:01.855 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:01.855 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/getHash.php:30]
2015-09-04 14:26:01.856 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.856 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:01.856 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:01.856 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:01.856 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/getHash.php:30]
2015-09-04 14:26:01.856 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.856 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.856 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.856 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.856 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:01.857 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.857 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.857 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.857 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.857 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.857 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:01.857 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:01.857 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:01.857 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/getHash.php:30]
2015-09-04 14:26:01.858 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.859 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.859 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.859 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.859 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.859 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:01.859 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1711]
2015-09-04 14:26:01.859 ***** ERROR ***** #4 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:01.859 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.859 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:01.860 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.860 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.860 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.860 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.860 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.860 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:01.860 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1539]
2015-09-04 14:26:01.860 ***** ERROR ***** #4 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1719]
2015-09-04 14:26:01.860 ***** ERROR ***** #5 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:01.860 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:01.861 ***** ERROR ***** #4 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1719]
2015-09-04 14:26:01.861 ***** ERROR ***** #5 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:01.861 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniresource' doesn't exist
2015-09-04 14:26:01.861 ***** ERROR ***** For query : select * from moniresource where moniresource.name='admin' and moniresource.isUser = '1'
2015-09-04 14:26:01.861 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.861 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.861 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1719]
2015-09-04 14:26:01.861 ***** ERROR ***** #2 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:01.974 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.974 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.974 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.974 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.974 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.974 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:01.975 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:01.975 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:01.975 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/loginCheck.php:30]
2015-09-04 14:26:01.975 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.975 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.975 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.975 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.975 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.975 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:01.976 ***** ERROR ***** Strack trace :
2015-09-04 14:26:01.976 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:01.976 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:01.976 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:01.976 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:01.976 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:01.976 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/loginCheck.php:30]
2015-09-04 14:26:01.976 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:01.976 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:01.976 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:01.981 ===== TRACE =====
2015-09-04 14:26:01.981 ===== TRACE ===== =====================================
2015-09-04 14:26:01.981 ===== TRACE ===== DataBase actual Version =
2015-09-04 14:26:01.981 ===== TRACE ===== ProjeQtOr actual Version = V5.0.5
2015-09-04 14:26:01.981 ***** ERROR ***** ERROR *****
2015-09-04 14:26:01.981 ***** ERROR ***** on file '/membri/monitoratti/projeqtor/tool/projeqtor.php' at line (2510)
2015-09-04 14:26:01.981 ***** ERROR ***** cause = set_time_limit() has been disabled for security reasons
2015-09-04 14:26:04.158 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:04.158 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:04.158 ***** ERROR ***** Strack trace :
2015-09-04 14:26:04.158 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:04.158 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:04.158 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:04.158 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:04.158 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:04.158 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/getHash.php:30]
2015-09-04 14:26:04.158 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:04.159 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:04.159 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:04.159 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/getHash.php:30]
2015-09-04 14:26:04.159 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:04.159 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:04.159 ***** ERROR ***** Strack trace :
2015-09-04 14:26:04.159 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:04.159 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:04.159 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:04.160 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:04.160 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:04.160 ***** ERROR ***** Strack trace :
2015-09-04 14:26:04.160 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:04.160 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:04.160 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:04.160 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:2564]
2015-09-04 14:26:04.160 ***** ERROR ***** #4 getSessionUser called at [/membri/monitoratti/projeqtor/tool/projeqtor.php:145]
2015-09-04 14:26:04.160 ***** ERROR ***** #5 require_once called at [/membri/monitoratti/projeqtor/tool/getHash.php:30]
2015-09-04 14:26:04.161 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:04.162 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:04.162 ***** ERROR ***** Strack trace :
2015-09-04 14:26:04.162 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:04.162 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:04.162 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:04.162 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1711]
2015-09-04 14:26:04.162 ***** ERROR ***** #4 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:04.162 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:04.162 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:04.163 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:04.163 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:04.163 ***** ERROR ***** Strack trace :
2015-09-04 14:26:04.163 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:04.163 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/Parameter.php:616]
2015-09-04 14:26:04.163 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:132]
2015-09-04 14:26:04.163 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1539]
2015-09-04 14:26:04.163 ***** ERROR ***** #4 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1719]
2015-09-04 14:26:04.163 ***** ERROR ***** #5 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:04.163 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [/membri/monitoratti/projeqtor/model/User.php:137]
2015-09-04 14:26:04.164 ***** ERROR ***** #3 User->__construct called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1539]
2015-09-04 14:26:04.164 ***** ERROR ***** #4 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1719]
2015-09-04 14:26:04.164 ***** ERROR ***** #5 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:04.164 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniresource' doesn't exist
2015-09-04 14:26:04.164 ***** ERROR ***** For query : select * from moniresource where moniresource.name='admin' and moniresource.isUser = '1'
2015-09-04 14:26:04.164 ***** ERROR ***** Strack trace :
2015-09-04 14:26:04.164 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:04.164 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1719]
2015-09-04 14:26:04.164 ***** ERROR ***** #2 SqlElement->getSingleSqlElementFromCriteria called at [/membri/monitoratti/projeqtor/tool/getHash.php:45]
2015-09-04 14:26:04.291 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_monitoratti.moniparameter' doesn't exist
2015-09-04 14:26:04.291 ***** ERROR ***** For query : select * from moniparameter where (idUser is null and idProject is null)
2015-09-04 14:26:04.291 ***** ERROR ***** Strack trace :
2015-09-04 14:26:04.291 ***** ERROR ***** #0 Sql->query called at [/membri/monitoratti/projeqtor/model/persistence/SqlElement.php:1579]
2015-09-04 14:26:04.291 ***** ERROR ***** #1 SqlElement->getSqlElementsF
04 Sep 2015 15:01 #6 by babynus
It seems you did not connect as admin/admin ?
if set_time_limit is disabled, you may have issue to install DB updates (may take few minutes on slow server)
Then you have some errors because db is not populated...
Not blocking (but I thought they were hidden ...)
No more in log file ?
There should be at least first db updates...
