ProjeQtOr free project management software - [SOLVED] import assignments with real work ==> the real work of activity not updated - ProjeQtOr
14 Aug 2015 13:47 #1 by yelazhari
Hi ,
I have a question about importing assignements :
When assignments are imported with a real work filled,the real work of the related activity is not updated, is that normal ? In my opignon , once the assignment is imported with real work , the real work of the actifity must be also recalculated and updated
14 Aug 2015 13:57 #2 by babynus
Yes, it is normal.
The real work is calculated from work in db, so each time you add assignment, without work item, real work is automatically updated to zero.
Same thing as real work for activity is sum of real work for all assignments on the activity.
14 Aug 2015 13:57 #3 by babynus
Yes, it is normal.
14 Aug 2015 14:05 #4 by yelazhari
So , you confirm if assignments are imported with a real work value ,the real work of the related activity will be also updated ?
14 Aug 2015 14:24 #5 by babynus
No, because real work of assignment will previously be set to zero, as there is no real work input (object work) on this assignement in the db.
14 Aug 2015 22:03 #6 by yelazhari
may be I did not understand well your explanation "as there is no real work input (object work) on this assignement in the db" , but looking at the assignment table I found that there's indeed a real work field in DB ( see the screen attached)?
could you explain me more?
Thanks a lot for your support and help
