ProjeQtOr free project management software - [SOLVED] Is it possible to customize reports ? - ProjeQtOr
04 Aug 2015 10:56 #1 by cnguyen
Hi all,
Using v5.0.1
I was wondering whether it was possible to customize the reports (eg monthly planning project/resource) in order to add a logo, some informations for a customer to sign the report ?
How can we do this if it is possible
Thanks in advance
Best regards
04 Aug 2015 11:45 - 04 Aug 2015 11:45 #2 by babynus
You have to update php file in /report directory.
Pay attention to save your changes ad they will be overwritten by next upgrade.
Last edit: 04 Aug 2015 11:45 by babynus.
The following user(s) said Thank You: cnguyen
