ProjeQtOr free project management software - Drop donw menus - ProjeQtOr
Drop donw menus
23 Jul 2015 15:05 #1 by Terfas Elmehdi
How can i change the order of elements in drop down menus. Example: to create a milestone i want "fixed milestone" to be selected by default instead of "floating milestone" in planning.
23 Jul 2015 15:11 #2 by babynus
Replied by babynus on topic Drop donw menus
Just change value of field "order" in corresponding screen.
For instance, in your exemple, change order in "Milestones types" so that "fixed milestone" is the fist one.
23 Jul 2015 15:42 #3 by Terfas Elmehdi
Replied by Terfas Elmehdi on topic Drop donw menus
Thanks for your quick response.
in activities and milestone types i did not find the planning values to change . where i can change it?
23 Jul 2015 15:53 #4 by babynus
I don't understand the request.
Please explain.
23 Jul 2015 16:00 #5 by Terfas Elmehdi
You said :
" For instance, in your exemple, change order in "Milestones types" so that "fixed milestone" is the fist one. "
I did not find "fixed milestone" or "float milestone" in "Milestone types" to change the order.
23 Jul 2015 16:17 #6 by Terfas Elmehdi
I found that i have to change the values of ordersort in "planningMode" table in database
if some milestones are already created will they be affected by this change of order value?
