ProjeQtOr free project management software - Connection to db via Unix Socket? - ProjeQtOr
12 Jul 2015 00:11 #1 by VERNCon
Is it possible to connect via unix socket to PGSQL, from Projeqtor?
Cheers,
Verncon.
12 Jul 2015 13:22 #2 by VERNCon
Got it sorted, all is OK.
12 Jul 2015 14:35 #3 by babynus
Hi, VERNCon
If you found a trick, please share with the community, it could help someone.
Thanks in advance.
12 Jul 2015 18:49 #4 by VERNCon
It was much simpler than I expected....
In the parameters.php file, at $paramDbHost value, all I needed to do was enter the Unix Sockets directory for the connection.
In my case (Fedora with PGSQL), I entered "/var/run/postgresql/" and re-started the httpd Service.
You need to have the database listening on the appropriate Unix Sockets - the default for PGSQL is /var/run/postgresql/ and /tmp.
The code used in this software is obviously much "nicer" than others, as I did the "usual" and I replaced the / 's with %2f, but then it complained that it could not parse the value.
I tried the straight text string including the forward-slash, it happily accepted it and the database connection came straight up. You still need to correctly edit the pg_hba.conf file correctly to control the access.
Cheers,
Verncon.
