ProjeQtOr free project management software - limitation number of projects - ProjeQtOr
13 Mar 2015 10:59 #1 by agarcia
We installed ProjeQtOr 4.5.5. After entering our projects (27 for now), I have a message that tells me that I have exceeded the number of projects in several pages display the monitoring menu.
Is this normal? How about it?
thank you
Best Regards
13 Mar 2015 14:50 #2 by babynus
This is normal limitation on Planning display, to avoid to block the browser (browsers have some issues where displaying large number of nodes).
So you have to select a project in the project selector (top left field) to access gantt.
The following user(s) said Thank You: agarcia
24 Mar 2015 16:10 #3 by tbergmann
How can the limit of projects be increased? The ressource planning is completely useless if it plans only in one project.
24 Mar 2015 16:13 #4 by babynus
The limlit of projects to be displayed on Gantt view si configured in global parameters screen.
