ProjeQtOr free project management software - [SOLVED] Unit of Work - ProjeQtOr
05 Jan 2015 12:09 #1 by Urtasun
Unit of Work was created by Urtasun
Is there any way to change the default unit of work from days to hours?
In the global parameters section, I have only two options: days and LDAP Host
Thanks in advance,
Martín
05 Jan 2015 12:19 #2 by babynus
Replied by babynus on topic Unit of Work
InGlobal Parameters, you have section "Unit for work" (maybe you have to unfold it to view content).
Here you have :
- unit for real work allocation : days or hours
- unit for workload : days or hours
- number of hours per day : take care to define correct value and never change it if some work is entered in hours (remember that projeqtor always store value in days and displays hours using this value for converstion)
Regards.
05 Jan 2015 13:43 #3 by Urtasun
Replied by Urtasun on topic Unit of Work
Thanks. I've found a little issue: in the spanish bundle, the option hours doesn't appear (it says "LDAP host"). With english languaje, it's ok.
05 Jan 2015 13:56 #4 by babynus
Translation issue confirmed.
Will be fixed on next version.
