ProjeQtOr free project management software - First launch error - ProjeQtOr
First launch error
19 Nov 2014 17:07 #1 by yexibit
First launch error was created by yexibit
I try to install on OVH server.
And, when i call projeqtor page an error occured :
Parse error: syntax error, unexpected '=', expecting '(' in /home/yegroup/www/projeqtor/view/main.php on line 24
Can you help me?
19 Nov 2014 17:12 #2 by babynus
Replied by babynus on topic First launch error
Which version of ProjeQtOr ?
(on V4.5.0, line 24 is inside a block of comments and does not contain any "=")
19 Nov 2014 20:14 #3 by yexibit
Replied by yexibit on topic First launch error
I have download the V4.4.2
19 Nov 2014 21:11 #4 by babynus
It seems your PHP version does not understand Object.
Maybe version is < V5.
You should create a .htaccess file with
SetEnv PHP_VER 5_3
The following user(s) said Thank You: yexibit
20 Nov 2014 15:08 #5 by yexibit
:cheer:
Thank you.
Problem resolved.
OVH has changed his PHP properties files in an other format.
