ProjeQtOr free project management software - step by step instruction on how to create a project and manage it - ProjeQtOr
06 Nov 2014 10:08 #1 by gesram
Is there a place where I can go to for a step by step instruction on how to create a project and manage it using Projeqtor?
I have a plan made using Open Proj. Is there a way I can use this to get a headstart instead of doing it from scratch.
My first hands on with Projeqtor. hence these fundamental questions
appreciate a respone
thanks
06 Nov 2014 13:05 #2 by babynus
First, please don't use existing Topic to ask a question.
Create a new topic in the corresponding section.
You post has been moved to correct place.
To answer your question, there is only some french guidelines existing.
You'll find it attached.
Will be included (and translated) on website.
