ProjeQtOr free project management software - Doubt in "Project Expense" Reports - ProjeQtOr
08 Oct 2014 19:35 #1 by francis2301
I have a doubt about the expected behavior in reports related to project expenses:
- Project expense per month
- Total expense per month
- Total Expense and Cost Per Month
I've entered some project expenses, filling out the fields planned cost & date and real cost & date.
When I run the reports mentioned above, costs are shown only in "real cost" line. Planned values are not shown.
At first, I thought it was because planned costs and real cost were the same. So, I changed values to have a difference between planned costs and real costs, and still showing no costs in the "planned cost" line, in the reports. I've tried also to change the date/month of real date, so it would be different from planned date, and still, no planned values were shown in the reports.
Is this a expected behaviour?
Also, I've noticed that when the values are in millions, the graph cuts the values on the left of the graph.
Attached follows a print screen of the values shown in the report and the graph.
Thanks in advance. Kind regards.
09 Oct 2014 11:29 #2 by babynus
This is designed behavior...
Target of these reports is to mesure total of expense, not to compare real from expected.
So for a given expense, if real is set, it is taken into account, if not then expected is taken into account.
Sorry, no file attached
09 Oct 2014 13:56 #3 by francis2301
Sorry for forgetting the attachment :S . But, you got it perfectly :cheer:
Maybe as evolution for cost reports would be some reports for comparing planned vs real.
Thanks for your answer and clarifying my doubt.
