ProjeQtOr free project management software - ..com/manual/manual.php?section=Today issues "404 not found" - ProjeQtOr
<sub-domain>.<domain>.com/manual/manual.php?section=Today issues "404 not found"
15 Sep 2014 21:25 #1 by gerold.kriechbaumer@gmx.net
Hi all,
In the Logo Area clicking the Help icon will NOT open the online user manual but issues "404 not found".
I have already read the topic Manual - File does not exist , but this topic does not solve my issue.
ProjeQtOr has been installed as suggested at a web hosting provider and will be called by using a sub-domain e.g. "pm.examples.com" and the Help icon calls "pm.examples.com/manual/manual.php?section=Today" which leads to "404 not found".
The access rights for the directories are set to 755 and for the files they are set to 644 respectively.
Any suggestions how to solve this issue?
Thanks for your answers.
Gary
17 Sep 2014 16:24 #2 by babynus
Strange : it works fine on Demo instance, with similar configuration.
It must be something with Apache configuration.
Maybe you can find interesting message in Apache log files.
23 Sep 2014 02:40 #3 by gerold.kriechbaumer@gmx.net
As an example, in the Apache log file, the following can be found:
[23/Sep/2014:02:20:03 +0200] "GET /manual/manual.php?section=User HTTP/1.1" 404 409 "sub-domain.domain.com/view/main.php" "Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/37.0.2062.120 Safari/537.36"
[23/Sep/2014:02:20:04 +0200] "GET /errors/404.jpg HTTP/1.1" 200 50656 "sub-domain.domain.com/manual/manual.php?section=User" "Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/37.0.2062.120 Safari/537.36"
Because I'm only a web application user not a web application developer, I cannot interpret the text and numbers.
So do YOU see anything in these lines what could lead to a solution for the problem?
23 Sep 2014 14:03 #4 by babynus
Second error line is just an Apache default behavior to try and display an error image (404.jpg).
Only first error must be concidered.
Page /manual/manual.php is not fond : possibly the root directory is not the expected one.
Check for root directpry of your virtualhost sub-domain.domain.com, it should point to Projector root directory, where /manual can be found.
24 Sep 2014 00:40 #5 by gerold.kriechbaumer@gmx.net
The sub-domain pointing is defined like the following:
The /ProjeQtOr folder looks like the following:
The /ProjeQtOr/manual folder looks like the following:
Any further ideas or suggestions?
24 Sep 2014 15:46 #6 by babynus
Very strange, all seems correct.
Could you try to directly access to sub-domain.domain.com/manual/manual.php
and check for apache error if any.
Time to create page: 0.062 seconds
