ProjeQtOr free project management software - Display problem with Planning Portfolio - Page 2 - ProjeQtOr
13 Sep 2014 01:31 #7 by babynus
I have an clue.
There is a small difference in access rights for Planning and Portfolio.
In planning, you see all activities and their project that you have read access to.
In portfolio, you see all project you have read access to.
So possibly you have some difference in read access (visibility) for projects and and activities.
Could you check access rights and affectations ?
20 Sep 2014 08:41 #8 by lepicard7
I tried everything: Unable to repair.
I exported csv files of projects, types lists, resources, actions, milestones ...
I reinstalled Projeqtor and a clean database and then I imported one by one the items exported above. In between, I did a back-up until I found the initial problem. It seems that had the resources that were problematic: probably a bug that was introduced during my first experiments.
I reconfigured all my resources at hand: Projeqtor working again fine now.
24 Sep 2014 19:34 - 24 Sep 2014 19:38 #9 by lepicard7
I have the same problem again ...
So I deployed a Projeqtor in which I created a single user (login = user1 / user1) as project leader / resource. I have not changed any other basic parameters of the application.
With user1, I created his project Proj1 and milestone Mil1:
The screenshot "user1_Planning" shows that user1 sees his project and its milestone in the planning.
But the screenshot "user1_Projects portfolio" shows that user1 sees his project but not its milestone in the Projects portfolio.
If I spend user1 as Administrator or Supervisor then he sees everything correctly.
I've attached an export of the corresponding database.
Last edit: 24 Sep 2014 19:38 by lepicard7.
24 Sep 2014 22:00 #10 by babynus
OK, I reproduced with your db.
I'll have a look.
24 Sep 2014 23:20 #11 by babynus
I found the issue.
The fix is : in /tool/jsonPlanning.php, replace line 96 from
$queryWhere.=getAccesResctictionClause('Project',$table);
to
$queryWhere.='('.getAccesResctictionClause('Project',$table).' OR '.getAccesResctictionClause('Milestone',$table).')';
Fix will be deployed in next version
