ProjeQtOr free project management software - How to organize a Project to obtain sub-totals of validated work - ProjeQtOr
29 Jul 2014 12:17 #1 by badgamme
In a project I created activities with type "Phase" and others (sub-activities) with type "Task" to order my stuff.
So I got a phase nammed "Analysis" with some tasks and a phase "Development" with others.
My questions :
1- is it the right way ? What's the impact of activity type on the behavior of the application ?
2- why didn't I get, in my phase, the amount of "validated work" of the sub-activities ?
Thank you
29 Jul 2014 12:34 #2 by babynus
Yes, It is a good way
Some fileds may be defined as mandatory depending on type. Also, workflow can be different.
Have a llok at Type fields.
Because it is designer this wa : in most cases, you don't know the validated work for sub-activities but for main ones, or just for phases.
So your entry should not be erase by null vlues of sub-activities.
An improvement will come in V4.4 to define how you'd like to sum-up validated work .
