ProjeQtOr free project management software - link activities between sub-projects - ProjeQtOr
10 Jul 2014 18:47 #1 by badgamme
I'm not able to link activities (predecessor/sucessor) between different sub-projects.
My purpose is to tell projeqtor : don't plan this ressource to this task of this project until this other task of this other project is finished.
When selecting predecessor list, I only find activities of the current sub-project.
Any solution ?
10 Jul 2014 18:56 #2 by babynus
2 solutions :
1) when adding dependency, use the search button (little magnifyer) beside activities list.
You will then be proposed a list of all activities you have access to, whatever the project. :)
2) On planning view, create link with drag & drop :woohoo:
The following user(s) said Thank You: amine-bendaoud
10 Jul 2014 19:04 #3 by badgamme
Just wonderfull !
